TedLasso
- Feb 23, 2016
Questions on Sonoff devices here including those flashed with Tasmota.
Important posts , references can be included in this first post ..
Edit:-
17/12/2019: How to Flash Sonoff to Tasmota :- For Windows use Tasmota-PyFlasher https://github.com/arendst/Tasmota/wiki/Flashing . Latest Tasmota Flash Binary will be found here:- http://thehackbox.org/tasmota/tasmota.bin
09/01/2020:-
Also get Termite(https://www.compuphase.com/software_termite.htm) , so that once your sonoff is flashed, and it reboots with Tasmota, you can use the current FTDI connection to send the configuration for WiFi etc
This is what I normally paste into the terminal using Termite connected to the Tasmota Sonoff after reboot.
Change everything in BOLD to your specific use case.
Backlog SSID1 WIFIAP; Password1 WIFIPASSWORD; MqttHost HASSIOIPADDRESS; MqttUser MQTTUSERNAME; MqttPassword REDACTED; Hostname Pool_Pump; MqttClient Pool_Pump; Topic Pool_Pump; FriendlyName1 Pool-Pump
Second config I push into each tasmota:-
backlog Switchretain 1;Powerretain 1;Timezone 2;latitude -26.000000;longitude 28.000000
Then you should see the device come online connect to your WiFI and then you will be able to connect to the web page to do other things
Edit:-
09/01/2020:-
