Sony Alpha A700
marine1
A black hole in the universe - JHB
Question:
*Vignetting will occur if the lens is used with digital cameras with image sensors larger than APS-C size or 35mm SLR cameras.
Does this apply to the Sony alpha A700?
Question:
iirc the A700 is a crop camera so vignetting for those reasons is unlikely.
As you can see - http://en.wikipedia.org/wiki/Vignetting - there are various reasons for vignetting.
So basically on my Alpha A700 I will not have this issue ?
Not for the reason you mentioned. You might experience vignetting for other reasons though.
Considering that the Sony has in-body stabilization, I think it's pretty unlikely that the lens is stabilized...
I couldn't find a Sony specific review (I didn't try very hard, I just got back from the pub and am too plastered) but the photozone review of the Canon one (1.6x crop factor. I think the Sony is 1.5x, so for the same lens vignetting should be *slightly* more) shows that there is some vignetting.
To be serious, there isn't a lens that doesn't have some level of vignetting. Even the best ones have a little (even FF lenses on a crop body). Nothing to break your head over. Aperture (and I'm sure Lightroom/DDP/CaptureOne/NX) have vignetting control that works pretty well. And even without that, with most lenses that that have reasonable levels of vignetting, i.e. 0.5 EV - 1.0 EV, it's not going to cause much of an issue.
MV's plugins, which I mentioned in the HDR thread, also has a Vignetting Corrector plugin which works Ok.
