Sony Xperia Z2 Battery Replacement
medicnick83
Paramedic
CBD, Cape Town
Hi all,
As per title; where can I take said phone to have the battery replaced? It doesn't last very long anymore.
I'm in Cape Town.
Thanks.
Have you done a full factory reset? Make sure you backup your data like photo's etc before you do it.
Don't worry, I'm sorted with that - thanks.
I just need to replace the battery - I can see I can buy the battery on eBay but suffice to say, rather take it to a "authorized replace place" :)
