Sound Card
Dolby
I'm currently using my onboard sound and decided recently to upgrade my speakers to Logitech Z-2300 which seem to have gt great reviews.
But - how badly would quality be compromised by using the standard, cheap onboard green output plug?
IMHO Sound cards have met their match in terms of quality to onboard. who buys these things nowadays?
however, i still prefer using my old trusty SB Live!
I don't think it will have much of a difference, only on performance, and maybe a *little* if you're a sound quality freak.
I was wondering the same thing, I have High Definition Audio (8-channel) sound and an old SB! Live lying around...I have been pondering for some time now if it is worth putting the SB in....Personally I think onboard sound now days is very capable of doing what separate sound cards can do, I think that is assuming you have bought a decent Mobo
And connections ... ? Don't higher end sound cards have actually analogue outputs as opposed to the minijack?
Not sure about that, all I know is my onboard has a digital line out, where as my SB doesnt'.
I used to have the Creative Audigy and i couldn't hear the difference when listening to music or watching movies. Although it enabled EAX® ADVANCED HD Effects in games. But i found this extremely irritating since it pretty much made everything resonate and gave an echo to speech. I had to turn up the speech volume and lower the sound effects and music to hear what a character was saying. I eventually just turned off the the EAX Advanced Effects. And a while after that i sold the card.
Ya nowadays I don't think it makes much of a difference for eg. listening to music. I think where it matters is where you get to high end audio editing/sampling etc.
BTW, nice buy!
Having a sound card installed frees up cpu cycles to do other stuff.
My onboard 5.1 sounds rubbish over my Logitech Z680's. Through my Audigy they sound brilliant. My 2 cents.
For movies and general music, onboard is fine. For gaming and higher-quality music, I recommend an Audigy or X-Fi.
