DominionZA
People still use 4 GB flash drives? I don't think you can even buy them anymore
Esquire sell them for about R40. I grabbed a whole lot a few weeks back. Very handy for storing OS installs etc..
Testing has shown that people cannot consistently reliably tell whether they're listening to good quality lossy compression or lossless/uncompressed.You're welcome to double blind test me using my audio equipment, clipping and compression even at 320kpbs is aweful. In fact, with semi decent sound equipment anyone other than the tone-deaf will probably be able to tell. MP3 is crap. Ultra crap. They'll do if you're using a R120 pair of earphones something, for anything decent I wouldn't touch them. FLAC for me, thanks.
You guys that rip the same CD to FLAC / MP3 320 to compare - how do you get passed the volume difference as well?
Although not massive, that alone gives me 100% success rate in telling the two apart. If both were perfectly equal volumes, it would make things a little more difficult at least
I've listened to music in forms of flv, mp3, FLAC etc...
On numerous systems except in the car.. I don't notice the difference..
Is there a difference ?
How accurately does a recording, even one using a lossless format, reproduce the true sound? For worse and for better, a recording may sound different to the actual sound. I've spent thousands of hours listening to piano music from dozens, if not hundreds, of CDs, on several different sound systems, and I'm always struck by how differently a live piano sounds to a recorded piano. I've attended piano concerts in acoustically well designed auditoriums with the music being played on well maintained Steinways, and I've listened to recordings of the same and other music also played on well maintained Steinways, and the recorded Steinway sounds different - rounder and gentler - to the live Steinway, which sounds more dimensionless and metallic (to me). Up close, the sound coming from a live piano, even at low volume, has an intensity to it that a sound system cannot recreate. The sound from a live piano fills up every part of a room and has the ability to linger almost endlessly for as long as the damper does not return to the string. One not only hears a piano at close range, you literally feel the sound as it vibrates through your body.
I didn't spend R20k. Or anywhere near that. I bought some high end equipment which varies from 10 to 30 years old
What equipment do you have that you can so easily tell the difference between a 320 rip and a FLAC recording?
I'm not saying the difference isn't there - but it isn't as glaring obvious as you're making out
He always is.Btw hope u all realise the op was trolling![]()
btw Dions does official Sennheiser repairs if you need them. Not sure as to price/service...but just fyi.I bought a pair of Sennheiser HD202s yesterday.
It easily takes on R15k home theater systems for sound quality, and cost me around a third of that.
Installed Foobar and the tester plugin now.
Queued up Team by Lorde, FLAC vs 320 kbps and managed to get 3/3.
The quality difference at beginning of the song (voice only) was especially distinguishable.
Not enough tests to be sure, I know. Will keep playing around when I have more time.
Yes it is, why do I need 5.1 for music? And the difference is pretty much day and night, MP3s have no... Life (?) to them.
Er, did you just say that you too can tell the difference every time?
