riscbroker
- Sep 29, 2006
I thought I was the only one that found this rather odd
But then I remembered the OP's propensity for trolling
You're welcome to double blind test me using my audio equipment
I use Apple Lossless.
And remember everyone. MP3 is the JPEG of audio codecs.
I'd love to test you. I do work in a high end audio studio, and I'd love you to tell me the difference between a high quality MP3 and RAW WAV/ AIF or FLAC as you so confidently claim.
Well I can honestly say that I can quite easily differentiate between MP3's at 128 vs 256.
I agree it might be overkill for the car and I was using my Senns but it is possible.
Oh so wanting decent sound is now inflating the size of the member?Not everybody inflates their ePeens by splashing R20k+ on a sound system.
What's wrong with JPEG ?
I don't get the reference :/ ..
^it's lossy.
I can tell the difference on both my sound system and my headphones. Did a double blind test with music I've ripped myself in both FLAC and MP3 and had a 95% success rate using certain recordings (Pink Floyd, Dire Straits, Fleetwood Mac, etc.). My Success rate dropped to 65% when it came to modern music (tried some Beyonce, Eminem, Deadmau5, etc.). In this second case I put it down to guessing more than actually being able to hear any difference.
Type of music has a huge impact, and a good recording (Such as Iron Hand by Dire Straits) will show the differences more clearly than less ideal recording (such as Metallica's entire Death Magnetic album).
With certain frequencies yes, but to be able to cherry pick those, it's virtually impossible.
It's about dynamics though.
Music has more life when it's not squashed into non-existence.
Why on earth you would rip music off YouTube...especially if you have it on CD is beyond me.
He's in a car...
And 6180gb of music. No thanks.
OP: As said above, just rip directly from the CD, not from Youtube. Rip it to 320Kbps and it should be fine for your car.
FLAC are overrated and too big. For car use, conversion from cd to mp3 at 320k is fine. Using FLAC you might get 4 albums on a 4gig stck - not worth it!
+192And that's a fail on my behalf, I read right past that. In a car there's too much ambient noise to bother with FLAC, 320kpbs MP3s should do. My apologies![]()
