Spar believes worst SAP deployment problems behind them
Jan
Who's the Boss?
Staff member
The Rabbit Hole
Spar estimates SAP rollout problems cost R1.6 billion in lost turnover
The Spar Group says the launch of its new SAP software system at its distribution centre in KwaZulu-Natal has resulted in an estimated turnover loss of R1.6 billion.
Moreover, its implementation led to an estimated loss of R720 million in profits. However, Spar says it has learnt a lot and will delay the rollout of SAP's system in other Southern African regions until management is satisfied with its optimisation.
There are many. I did about 15 years of SAP consulting work and 99% of the full life cycle implementations I worked on worked well.
Also keep in mind SAP ERP is not the same as SAP EWM etc.
Many many companies runs SAP products very successfully.
In budget and on time?
That's ok, just raise the prices even more, and make more pricing "mistakes" to make up for that.
I've never heard of one SAP implementation that went smoothly
To be fair, the companies that can afford SAP also have hellishly complicated requirements, mostly self inflicted because they are squeezing their suppliers and customers so hard.
Imagine trying to keep a product in stock, when you ask your suppliers to only deliver the minimum so you save on storage space and save cashflow on supplier payments, then you expect your logistics company never to miss a delivery so you run fewer trips. Then you short staff the stores that keep the shelves stocked.
They can make things so much simpler if they simply built better margins for disruption. You will have happier customers, a happier workforce and more reliable suppliers if you do. But your profits might be 0.5% lower.
Where do you get your info from. Many have implemented SAP smoothly and under budget.
Not Shoprite, PnP or Spar... that's for sure
I've experienced the hell of all of these first hand.
The economy is f***ed and probably the biggest reason behind their decline, just like any of the other companies reporting huge losses. If they still want to blame SAP, they are idiots, so are those buying franchises or investing in them.
