Hi Guys
I need some help with regards to my car, you have always pointed me in the right direction in the past.
Yesterday I noticed a slight misfiring, rough idling and loss of power. I got home, decided to look out for the common issues, oil and stuff. Oil seems to be fine, no water-oil mix or whatsoever.
This is where it gets interesting, my spark plugs are in a hollow position. I took the lead cables leading to spark plugs out and noticed some water in the left one, all other three were dry and normal.
I drained the water, put the lead cables back and started the car, car idles normal and no rough idling.
I have been trying to figure out how the water got in there,but can't seem to get it. There is a cover that you need to remove first to get to the plugs.
My question is, could this be a leak of some sort from underneath where the plugs fit in? Could it be a a blown gasket?
TIA
TIA
