Speed / Ping issues.
Mephisto_Helix
Resident Postwhore
UK
So, while the cable was busted, my local speeds and pings were completely normal right, now the cable is fixed and my line is going whacky. I have dial-up speeds and my ping is jumping from 300-800. That's is on my local only IS account and my SAIX unshaped account :confused: Is anyone else experiencing this?
Have you tried turning off your router for 60 seconds and turning it on again. Sorry for sounding like the IT crowd: "Have you tried turning it on and off again." :D
Yep, did that already, no joy whatsoever ......
Edit* - a port refresh has done the trick (for now) :D
Just to clarify this for someone who might have the same problem. Mephisto_Helix: Please clarify that this is correct.
> Give your ISP a ring and ask them to reset your port on the exchange.
No, phone Telkom and ask them to refresh the port on the exchange ..... a reset is a different thing altogether ;)
Ok, so obviously the port refresh was a fluke .... problems are back :wtf: Some odd tracerts and pingtests and they vary in the space of 10 minutes -
Earlier Tests: SAIX account and then IS account
Code:
Microsoft Windows [Version 6.1.7600]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Andre>ping saix.co.za
Pinging saix.co.za [196.25.1.200] with 32 bytes of data:
Reply from 196.25.1.200: bytes=32 time=286ms TTL=251
Reply from 196.25.1.200: bytes=32 time=341ms TTL=251
Reply from 196.25.1.200: bytes=32 time=347ms TTL=251
Reply from 196.25.1.200: bytes=32 time=228ms TTL=251
Ping statistics for 196.25.1.200:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 228ms, Maximum = 347ms, Average = 300ms
C:\Users\Andre>ping www.mygaming.co.za
Pinging www.mygaming.co.za [41.203.21.136] with 32 bytes of data:
Reply from 41.203.21.136: bytes=32 time=390ms TTL=56
Reply from 41.203.21.136: bytes=32 time=374ms TTL=56
Reply from 41.203.21.136: bytes=32 time=389ms TTL=56
Reply from 41.203.21.136: bytes=32 time=464ms TTL=56
Ping statistics for 41.203.21.136:
    Minimum = 374ms, Maximum = 464ms, Average = 404ms
C:\Users\Andre>tracert saix.co.za
Tracing route to saix.co.za [196.25.1.200]
over a maximum of 30 hops:
  1   435 ms   507 ms   595 ms  dsl-146-12-01.telkomadsl.co.za [165.146.12.1]
  2   533 ms   434 ms   396 ms  wblv-ip-essr-1-atm-2-0-0-2.telkom-ipnet.co.za [1
96.43.11.30]
  3   196 ms   261 ms   255 ms  wblv-ip-www-1.saix.net [196.25.1.200]
Trace complete.
C:\Users\Andre>tracert www.mygaming.co.za
Tracing route to www.mygaming.co.za [41.203.21.136]
  1   402 ms   374 ms   394 ms  dsl-146-12-01.telkomadsl.co.za [165.146.12.1]
  2   457 ms   409 ms   461 ms  wblv-ip-lir-1-gig-4-0-0.telkom-ipnet.co.za [196.
43.8.190]
  3   414 ms   408 ms   456 ms  196.43.25.206
  4   314 ms   317 ms   323 ms  ge0-3.br2.cpt1.za.mtnbusiness.net [196.7.8.206]
  5   336 ms   373 ms   355 ms  ge11-0-0.gw2.jnb6.za.mtnbusiness.net [196.30.1.2
2]
  6   449 ms   408 ms   306 ms  vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.13
6]
  7    48 ms    48 ms    56 ms  196.30.213.108
  8    43 ms    45 ms    44 ms  firewall1.jnb2.host-h.net [196.7.216.173]
  9    44 ms    64 ms    87 ms  mybroadband.co.za [41.203.21.136]
Trace complete.
Reply from 196.25.1.200: bytes=32 time=49ms TTL=244
Reply from 196.25.1.200: bytes=32 time=48ms TTL=244
    Minimum = 48ms, Maximum = 49ms, Average = 48ms
Reply from 41.203.21.136: bytes=32 time=72ms TTL=52
Reply from 41.203.21.136: bytes=32 time=27ms TTL=52
Reply from 41.203.21.136: bytes=32 time=28ms TTL=52
    Minimum = 27ms, Maximum = 72ms, Average = 38ms
  1    17 ms    16 ms    14 ms  196-209-1-1-ndn-esr-2.dynamic.isadsl.co.za [196.
209.1.1]
  2    25 ms    25 ms    27 ms  cdsl1-rba-vl2253.ip.isnet.net [196.38.73.181]
  3    24 ms    24 ms    27 ms  cdsl1-rba-vl150.ip.isnet.net [196.38.73.17]
  4    25 ms    25 ms    27 ms  core5a-rba-gi1-0-0.ip.isnet.net [168.209.1.164]
  5    26 ms    24 ms    24 ms  196.26.0.10
  6    24 ms    25 ms    25 ms  rrba-ip-spe-2-wan.telkom-ipnet.co.za [196.25.127
.181]
  7    32 ms    25 ms    25 ms  196.43.25.137
  8    48 ms    48 ms    48 ms  wblv-ip-essr-1-atm-2-0-0-2.telkom-ipnet.co.za [1
96.43.11.30]
  9    59 ms    48 ms    53 ms  wblv-ip-www-1.saix.net [196.25.1.200]
Trace complete.
  1    15 ms    15 ms    15 ms  196-209-1-1-ndn-esr-2.dynamic.isadsl.co.za [196.
209.1.1]
  2    26 ms    26 ms    28 ms  cdsl1-rba-vl2253.ip.isnet.net [196.38.73.181]
  3    25 ms    24 ms    24 ms  cdsl1-rba-vl150.ip.isnet.net [196.38.73.17]
  4    24 ms    25 ms    25 ms  core5a-rba-gi0-0-0.ip.isnet.net [196.26.0.42]
  5    32 ms    26 ms    24 ms  168.209.1.179
  6    25 ms    25 ms    25 ms  ge0-1.br1.jnb7.za.mtnbusiness.net [196.30.228.24
1]
  7    25 ms    26 ms    26 ms  ge0-1.cr1.jnb7.za.mtnbusiness.net [196.30.228.12
2]
  8    26 ms    26 ms    26 ms  196.30.1.21
  9    27 ms    27 ms    27 ms  vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.13
6]
 10    26 ms    32 ms    28 ms  196.30.213.108
 11    26 ms    29 ms    27 ms  firewall1.jnb2.host-h.net [196.7.216.173]
 12    28 ms    29 ms    29 ms  mybroadband.co.za [41.203.21.136]
Trace complete.
Latest Tests: SAIX account and then IS account
Code:
Reply from 196.25.1.200: bytes=32 time=38ms TTL=251
Reply from 196.25.1.200: bytes=32 time=37ms TTL=251
Reply from 196.25.1.200: bytes=32 time=36ms TTL=251
    Minimum = 36ms, Maximum = 38ms, Average = 37ms
C:\Users\Andre>ping [url]www.mygaming.co.za[/url]
Pinging [url]www.mygaming.co.za[/url] [41.203.21.136] with 32 bytes of data:
Reply from 41.203.21.136: bytes=32 time=46ms TTL=56
Reply from 41.203.21.136: bytes=32 time=49ms TTL=56
Reply from 41.203.21.136: bytes=32 time=44ms TTL=56
    Minimum = 44ms, Maximum = 49ms, Average = 46ms
  1    16 ms    15 ms    14 ms  dsl-146-12-01.telkomadsl.co.za [165.146.12.1]
  2    39 ms    39 ms    39 ms  wblv-ip-essr-1-atm-2-0-0-2.telkom-ipnet.co.za [1
96.43.11.30]
  3    36 ms    38 ms    36 ms  wblv-ip-www-1.saix.net [196.25.1.200]
Trace complete.
C:\Users\Andre>tracert [url]www.mygaming.co.za[/url]
Tracing route to [url]www.mygaming.co.za[/url] [41.203.21.136]
  1    14 ms    16 ms    15 ms  dsl-146-12-01.telkomadsl.co.za [165.146.12.1]
  2    40 ms    46 ms    39 ms  wblv-ip-lir-1-gig-4-0-0.telkom-ipnet.co.za [196.
43.8.190]
  3    42 ms    41 ms    42 ms  196.43.25.206
  4    43 ms    46 ms    46 ms  ge0-3.br2.cpt1.za.mtnbusiness.net [196.7.8.206]
  5    48 ms    45 ms    46 ms  ge11-0-0.gw2.jnb6.za.mtnbusiness.net [196.30.1.2
2]
  6    44 ms    44 ms    43 ms  vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.13
6]
  7    53 ms    45 ms    50 ms  196.30.213.108
  8    44 ms    43 ms    47 ms  firewall1.jnb2.host-h.net [196.7.216.173]
  9    45 ms    44 ms    45 ms  mybroadband.co.za [41.203.21.136]
Trace complete.
Reply from 196.25.1.200: bytes=32 time=73ms TTL=244
Reply from 196.25.1.200: bytes=32 time=182ms TTL=244
Reply from 196.25.1.200: bytes=32 time=291ms TTL=244
Reply from 196.25.1.200: bytes=32 time=242ms TTL=244
    Minimum = 73ms, Maximum = 291ms, Average = 197ms
Reply from 41.203.21.136: bytes=32 time=31ms TTL=52
    Minimum = 27ms, Maximum = 31ms, Average = 29ms
  1    18 ms    14 ms    14 ms  196-209-1-1-ndn-esr-2.dynamic.isadsl.co.za [196.
209.1.1]
  2    81 ms   126 ms   109 ms  cdsl1-rba-vl2253.ip.isnet.net [196.38.73.181]
  3    25 ms    26 ms    25 ms  cdsl1-rba-vl150.ip.isnet.net [196.38.73.17]
  4    80 ms    66 ms    52 ms  core5a-rba-gi1-0-0.ip.isnet.net [168.209.1.164]
  5   130 ms   126 ms   158 ms  196.26.0.10
  6    26 ms    24 ms    30 ms  rrba-ip-spe-2-wan.telkom-ipnet.co.za [196.25.127
.181]
  7    25 ms    24 ms    25 ms  196.43.25.137
  8    53 ms    48 ms    49 ms  wblv-ip-essr-1-atm-2-0-0-2.telkom-ipnet.co.za [1
96.43.11.30]
  9    49 ms    52 ms    48 ms  wblv-ip-www-1.saix.net [196.25.1.200]
Trace complete.
  1    14 ms    18 ms    14 ms  196-209-1-1-ndn-esr-2.dynamic.isadsl.co.za [196.
209.1.1]
  2    25 ms    24 ms    27 ms  cdsl1-rba-vl2253.ip.isnet.net [196.38.73.181]
  3    39 ms    33 ms    26 ms  cdsl1-rba-vl150.ip.isnet.net [196.38.73.17]
  4    36 ms    34 ms    25 ms  core5a-rba-gi0-0-0.ip.isnet.net [196.26.0.42]
  5    26 ms    25 ms    24 ms  168.209.1.179
  6    25 ms    24 ms    25 ms  ge0-1.br1.jnb7.za.mtnbusiness.net [196.30.228.24
1]
  7    53 ms    50 ms    41 ms  ge0-1.cr1.jnb7.za.mtnbusiness.net [196.30.228.12
2]
  8    42 ms    26 ms    27 ms  196.30.1.21
  9    26 ms    26 ms    25 ms  vlan9.hr3.jnb6.za.mtnbusiness.net [196.30.156.13
6]
 10    40 ms    27 ms    27 ms  196.30.213.108
 11    30 ms    29 ms    27 ms  firewall1.jnb2.host-h.net [196.7.216.173]
 12    27 ms    27 ms    27 ms  mybroadband.co.za [41.203.21.136]
Trace complete.
It just looks all out of whack to me, so the question is, is it the line or just general internet issues, possibly related to all the crud we've had lately?
I have the same problem, 1Mbps account from MWeb, new 2Mbps line form Telkom and speeds are ridiculously low. I keep refreshing ports (@telkom) and re-auth'ing the account (@MWeb) but changes in speed don't last for more than 2 days. Dafuq??? Please help, any suggestions???
can you try doing a http://www.pingtest.net test - I see you in Durban, maybe the weather has messed up your line, do you hear noise on your landline?
Hi Keegan, I have done the speedtest, resulting in a 72ms ping, but don't really know how to interpret the other results.
jitter is 57ms
line quality is only C (with MOS 4.25)
MWeb is rated 2.6/5.
Any suggestions?
jitter is 57ms
Any suggestions?
Hi
I suggested the pingtest for Mephisto_Helix
But basically if your jitter is that high its due to your line not being in good order.
You need telkom to get your line checked.
