SQL Select Statement Help
Pho3nix
The Legend
On the toilet
Hi all,
Brain isn't helping this morning with a query.
Have a table with 6 fields. Project,Task,Resource,Status,Date and Hours.
I know there are duplicates here but combing through 4000 records and trying to find them isn't working.
Anyway to script this ? :o.
Duplicates would be where the first 4 fields are the same but there is time logged for 2 different statuses.
Any help would be appreciated.
SELECT count(id), * FROM table group by project,task,resource
and a bit of editing to find specific fields where count >1
SELECT project,task,resource FROM table group by project,task,resource
having count(*) > 1
Made a boo boo. First 4 fields make the record unique. Can't group with out having a column in the * in the group aswell.
[table="width: 500"]
[tr]
[td]Project[/td]
[td]Task[/td]
[td]Resource[/td]
[td]Date[/td]
[td]Time[/td]
[td]Status[/td]
[/tr]
[tr]
[td]1[/td]
[td]1[/td]
[td]1[/td]
[td]2011-06-29[/td]
[td]5[/td]
[td]1[/td]
[/tr]
[tr]
[td]1[/td]
[td]1[/td]
[td]1[/td]
[td]2011-06-29[/td]
[td]8[/td]
[td]2[/td]
[/tr]
[/table]
depends on what you are going for here. you could also use DISTINCT or you can group, I think the best approach would be DISTINCT.
so SELECT DISTINCT Project,Task,Resource,Status,Date and Hours FROM table.....
Managed with a CTE. Your post got me the idea to google NOT DISTINCT which led me to an answer.
Code:
;with counts as (
    select ProjectId,TaskId,ResourceId,TimesheetLineStatusId,TimeByDay,HourlyTime,IsAdmin,
      count(*) over (partition by ProjectId,TaskId,ResourceId,TimesheetLineStatusId,TimeByDay) as num
    from staging.TempUpdateTimesheet
from counts
where num > 1
order by TimeByDay asc
This would still give me all the records that aren't duplicates :cry:
