SSD not detected, help
Tongs of Destiny
ok do I found my old PC 60gb SSD drive in the cupboard (as far as I remember it worked fine years ago) I upgraded it as it was small.
I've now bought a SSD usb case, I plug in my other drives to this case and they all work perfectly. When I plug this one in nothing shows on file explorer? nothing shows in disk management either, or even the bios.
who amongst the masses is smart enough to solve this issue :cool:
Does it work if you plug it directly into a motherboard sata port?
