Standard sim in USB modem = ? speed
robass
Port Elizabeth
Just wanting to find out what speeds I would be getting if I use a standard 32k sim in my now, no-longer used E620 modem ?
Changing topic slightly . Can you put a vodacom sim card into the MTN modem and will it work ?
Thanks Park , is it also just a "plug and play" configuration . I will test it tonight , I will try the MTN sim and then the Vodacom sim and see which one gives me the best results .
O.K. Got home and inserted the sim card and everything is working fine . Now how do you tell how many megs you have left , do you have to remove the sim card, insert it into a phone and then dial and request your available data ??
register on www.vodacom4me.co.za > my account > data bundles will give you the balance.
