Starsat HD Decoder Resolution
grootgeel
Port Elizabeth
Hi all.
My friend got himself a starsat HD decoder. Unfortunately his tv is only HD Ready (Can only display HD up to 720p)
On DSTV you can set the resolution to your screen, but we can't find such a setting on starsat. It's set to 1080i or your normal rca cables with 576p. Does anybody know of a way to change the decoder to display 720p?
Thanks.
If it is broadcast at 1080i, changing the setting on the decoder will only make the scaling happen on the decoder, instead of the screen. I would rather entrust that job to the screen.
Hi. I trully need help.
I just installed a hd pvr 2p and it keeps giving me error hdcp… I have specs for my lg 50" 3d TV which is compatible.
Here are the specs :
3D SPECIFICATIONS
3DSG TypeCompatible 3D GlassesAG-S250 ONLY2D to 3DYes (2D Step Adjustability)3D to 2DYes3G Glasses (AG-S250) compatible(Not included)
BROADCASTING SYSTEM
AnalogNTSCDigitalATSC/NTSC/Clear QAM (1 Tuner)
VIDEO
Dual XD® EngineYesAspect Ratio16:9Aspect Ratio Correction5 Modes (16:9/Just Scan/Original/4:3/Cinema Zoom)Color Temperature Control3 Modes (Warm/Medium/Cool)Picture Mode10 ModesJust Scan (1:1 Pixel Matching)HDMI™: 1080p/1080i/720p, Component: 1080p/1080i/720p, RF: 1080i/720pxvYCCYes24p Real Cinema (3:3 Pulldown)Yes (HDMI 1080 24p)Cinema 3:2/2:2 Pull Down ModeYesHD Up-convertingYesAV ModeYes (Cinema/Game/Sport)XD Color (Active Color Management)YesISFccc® ReadyYesIntelligent Sensor ModeYesDTV Signal StrengthYes
AUDIO
Mono/Stereo/Dual (MTS/SAP)YesAudio Output Power (Watts - THD 10%)10W + 10WDolby® Digital DecoderYesSpeaker System1 Way 2 SpeakersSurround SystemInfinite SoundBass/Treble/Balance ControlsYesAuto Volume Leveler IIYesClear Voice IIYesSound Modes5 Modes (Standard/Music/Cinema/Games/Sports)
SPECIAL FEATURES
Picture Wizard IIYesSmart Energy SavingYes1080p Source InputHDMI: 60p/30p/24p, Component: 60p/30p/24p, RGB: 60p (WXGA)A/V Input NavigationYesInput LabelingYesScreen AdjustYesQuick View (Flashback)YesPicture FreezeYesParental Control w/V-ChipYesClosed CaptionYesSIMPLINK (HDMI CEC) Yes (All HDMI)
CONVENIENCE FEATURES
Language4 (English/Spanish/French/Korean)Auto Tuning/ProgrammingYesChannel Add/DeleteYesFavorite Channel ProgrammingYesAuto/Manual ClockYesOn/Off TimerYesSleep TimerYesAuto Off (Sleep)Yes
SIDE INPUTS & OUTPUTS
AV In1HDMI™/HDCP Input1USB 2.0 (Music/Photo/Movie)1
REAR INPUTS & OUTPUTS
RF In (Antenna/Cable)1AV In1Component Video In (Y, Pb, Pr) + Audio 2Digital Audio Out (Optical) 1HDMI™/HDCP Input2RGB In (D-Sub 15pin) - PC1PC Audio Input1Wired IR Jack1RS-232C (Control/Service)1Remote Control In1
CABINET/ACCESSORIES
Swivel20º/20ºUL StandardYesVESA Compatible400mm x 400mmRemote ControlStandard
POWER
Power Supply (Voltage, Hz)100V ~ 240V, 50/60 HzConsumption148WOn Mode (Average)TBDStandby Mode0.2W
Please helpas I can't view via hdmi
Did you buy this tv in south africa?
I noticed that your tv tuner is ntsc. We use pal in south africa. I know that it is only on the analog side and not through the hdmi connection, but isn't it checking or searching for a ntsc signal. Have you tried "auto" on your hdmi connections?
