Nocturnity
I have a really weird problem and no-one can give me any clear indication of what to look for to fix it!
My setup:
1. SAOL uncapped 384K ADSL with static IP running on a billion 4-port router/modem they supplied.
2. D-LINK DI-604 router with an internal IP range set up with the SAOL router as the gateway and DHCP enabled.
3. 2 machines and a printer on the internal IP range.
I can acces the net without problems and i can download like crazy but I can't seem to get data out for some reason. When I try send mail through SMTP, webmail or GMAIL it times out. Also, when browsing some sites that require you to submit forms, they time out.
When I plug the PC directly into the static router and assign it the live IP, everything works fine!
I've tried everything from resetting the router, flashing the firmware, changing IP ranges, you name it! I've been struggling with this one for 4 weeks now!
Any help would be greatly appreciated!
My setup:
