Hi All,
I am turning to MYBB to solve my problem (if possible). Google is failing me.
My aim: I am trying to setup a PC in order to do teleradiology from home with my limited network knowledge. My current setup. I was told I need a static IP address form my ISP. I can't use DDNS or something similar. Think it is a limitation of the software used. So my requirement is to get 1 pc (a mac) to connect to the internet with a static IP. I also need to forward some ports to the mac. I then have multiple other devices that needs to connect to the internet without the need for a static ip.
Current setup: When applying for a static IP the ISP provide you with a pre-configured router. I signed up with Cybersmart and was a sent a Billion router. I connected this router to my phone line. I have the Mac connected to the billion with a static IP assigned. I then have my previous Cisco router connect to the Billion with the other available static IP. The rest of my network then connects to the Cisco and gets assigned internal dynamic IP's.
1. DSL line
2. Billion
3.1 Mac (connected to Billion)
3.2 Cisco router (Connected to Billion)
4. All other devices - smart phones, laptops etc (Connected to Cisco)
The problem: The radiology software techs informed me that they need to forward some ports to the mac in order for the software to work. Cybersmart said they can't do it on their side (I believe some other ISP's do) and forwarding the ports on the router also seems to be a problem. With the pre-configured router the NAT has been disabled and according to the manual if you disable the NAT port forwarding becomes invalid.
Is there any other configuration that will ensure the MAC gets assigned a static IP and I can do port forwarding to the Mac via one of the routers. This seems like a complex problem because after a week and a half struggling between the ISP and the radiology service provider I am still no closer to a solution.
Last question - Where can I start looking for a networking expert to help as I assume this knowledge wont reside in the retail outlets (incredible connection, etc). I am based in Pietermaritzburg.
1. DSL line
2. Billion
