Jonny Two Shoes
Hey all...here's an interesting one I'm having. (Not sure if this belongs here or under hardware but we shall see
We have a Utax printer with scanner. The scanner is on it's own IP address.
All of our PC's are on the same domain with same subnet.
All of our PC's use DHCP controlled by the server.
The scanner is not on DHCP but has been set up correctly and been working fine for a while.
Here is the scenario...
Scanner is having intermittent problems sending PDF scanned jobs to certain PC's (quite a few) on the 1st floor to the people close by to it (fails 90% of the time and times out). However it sends the jobs 100% fine to me all the time and to some previous users who have now moved to other areas in the building. Although pinging the scanner IP address from any PC even the problem PC's show replies with no errors.
Another scanner (same type but different IP) sends jobs perfectly fine to the problem PC's (this is what confuses me - I mean
All network points throughout the building are directed to a main switch via ethernet cables. (well...switches...there are a few in a rack)
The only changes I know of late is the installation of a new IP phone system that of course tampers a lot with the network but I'm not involved with this project.
So...
1. "Problem scanner" is working fine. It sends jobs 100% fine to me and others.
2. "Problem PC's" are fine. They receive scans from the same type of device from another part of the building.
3. Network cables are fine no? They receive comms from the other devices through the same path.
All I can imagine is that perhaps there is a problem between certain (elaborate on certain) ports only on the switch? But is that possible? If comms from other areas through those points are fine how can that be?
Or alternatively the IP phones are causing an issue...but surely other network resources would be affected? Not just one "specific" scanner.
Any thoughts or something I may be missing?
So...
