Does anybody know of someone that can solder on a surface mount plug for me? I have already ordered the broken part[zif-type plug] but I don't have the right tools nor steady hand to attempt it myself. Normally I would attempt it myself anyway using the wrong tools, but in this case I would _really_ like my phone to still work after it's soldered. 6 tiny little pins on the plug no 3 that connects the speaker above the screen and proximity sensor to the mainboard.
Basically I did exactly what all these dumbasses here did:
http://www.hackint0sh.org/f131/68774-2.htm#post412622
Background:
After some very good use of my iPhone I got a cat hair (really) in my screen between the glass and screen. Besides this it also had loads of dust there so I decided to open the phone as I always have to open everything up to satisfy my curiosity. Everything went well, I got the hair out, dusted it a bit and while reassembling it I broke said connector. In retrospect it is clear that I should never even have opened it - if it ain't broke, blah.
Background:
