Crumbl0x
- Mar 18, 2020
Oh thanks for confirming that! I thought the spec of ARC was basically S/PDIF over HDMI so the limitations of one applied to the other but the more posts I come across the more I see it's definitely not the case (lower level Atmos can even be sent over ARC), and it makes sense in that regard, apologies for thatARC is not the same as optical, arc does support DD+. eARC has higher bandwidth and can do Atmos
