carstensdj
Hey forumites.
I need some advice please. I have a 2005 VW Polo 1.4 (9n3) with 188,000kms on the clock. I need to have the motor done over as the rings and valve stem seals all need replacing (and probably a bunch of other things) and it's losing a lot of oil. I've been advised by many to rather swap the motor out for a 2.0 8v APK (Golf 4 motor, also used in the 2.0 Polo's). The costs would work out to fairly similar amounts, which ever way I go.
My question is: Is it a straight swap or do I need to change the gearbox too? I can't tell you how many mixed answers I've had on this, talking to mechanics and Motor places. Has anyone done this swap or know a little bit about it?
Budget is an issue for me and I've had to save up to sort my car out, so I want to make sure i'm doing the right thing. I drive it daily to and from work and also often, for work. I should also mention that I'm a big petrol head and do enjoying driving a little quicker than the average person, so the idea of the APK swap does entice me. It's just that if I need to change the gearbox too, it sets me back budget wise a little bit...
Thanks in advance!
Thanks in advance!
