SWScanner from AUR bujild issues?
ponder
Niflheimr
Trying to install SWScanner from AUR with yaourt but I'm getting the following error,
Code:
/usr/include/qt3/qstring.h:365:94: warning: conversion to ‘unsigned int:30’ from ‘uint {aka unsigned int}’ may alter its value [-Wconversion]
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/opt/kde/include -I/usr/include/qt3 -I.  -I/usr/include/libshp  -DQT_THREAD_SUPPORT -D_FORTIFY_SOURCE=2 -D_REENTRANT  -Wnon-virtual-dtor -Wno-long-long -Wundef -Wall -W -Wpointer-arith -Wwrite-strings -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -O2 -march=i686 -mtune=generic -O2 -pipe -fstack-protector --param=ssp-buffer-size=4 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common -Wno-non-virtual-dtor  -MT ifaces.o -MD -MP -MF ".deps/ifaces.Tpo" -c -o ifaces.o ifaces.cpp; \
then mv -f ".deps/ifaces.Tpo" ".deps/ifaces.Po"; else rm -f ".deps/ifaces.Tpo"; exit 1; fi
ifaces.cpp: In function ‘int if_fetch(interface*)’:
ifaces.cpp:90:13: error: ‘close’ was not declared in this scope
     close(fd);
make[2]: *** [ifaces.o] Error 1
make[2]: Leaving directory `/tmp/yaourt-tmp-****/aur-swscanner/src/swscanner-0.2.2/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/tmp/yaourt-tmp-****/aur-swscanner/src/swscanner-0.2.2'
make: *** [all] Error 2
==> ERROR: A failure occurred in build().
    Aborting...
==> ERROR: Makepkg was unable to build swscanner.
==> Restart building swscanner ? [y/N]
The **** above is my edit.
Any ideas?
Oh, 32-bit
I quickly had a look at it and saw it is abandoned. The last official release was in 2006. I would move on if I were you.
