Sympatico PPPOE issue
greg bales
Hi, i just moved from Normal type ADSL broadband from my home in Newyork.
and now in Toronto (sympatico) uses routerPPPOE type broadband.
Ever since i wired up the connection 3 days ago Ive been having trouble with my connection randomly flashing about every .5-1hour. t
he whole Internet gateway connection would disappear from Network Connections and then my Ethernet adapter would display that my cable is unplugged, then it would give me 100mbLAN and flash back and forth multiple times.
shortly after the gateway would re-appear and everything would be fine again.
Sometimes the routers can be kind of sketchy. So I disabled my routersPPPOE autoconnect. and used the windows XP manual PPPOE connect, hoping it would solve my problems.
still nothing. if anyone with greater knowledge in the PPPOE area could help me, I'd really appreciate it. thx.
-Greg Bales
onboard Nforce2 E-adapter
Speedstream 6520 router/modem combo
Hi guys,
I don't want to make you feel unwelcome, or anything like that - but this site is dedicated specifically to broadband not-very-good solutions in SOUTH AFRICA - That's this country at the southern tip of the African continent.
You might get more localised help if you ask on a broadband forum that is focused on the USA.
Otherwise - welcome - feel free to participate. :D
Heh. I feel quite chuffed that the expats are discussing their international issues here in this forum :) And LOOK! He got an answer too!
I almost got a heart attack at first. Sympatico in South Africa! Deregulation on the fasttrack! ?
