Ockie
Resident Lead Bender
T-Mobile will require VoLTE compatible devices for future line activations
In anticipation of T-Mobile’s phasing out of 3G networks, the company will no longer support 3G-only devices starting in January.
Please elaborate and/or post links to help us out.Most android phones are volte compatible, it's been operators disabling it and them messing up rolling it out that caused people to disable it if they even had it (I'm specifically looking at you Vodacom).
Carriers need to tell the phone that their network is able to support VoLTE. They usually have a database with a list of phones that they will respond true to so that they can use it.Please elaborate and/or post links to help us out.
The above flag up used to be set to false by Vodacom and MTN handsets a few years ago, so no matter where you took the phone VoLTE didn't work.KEY_CARRIER_VOLTE_AVAILABLE_BOOL
Added in API level 23
public static final String KEY_CARRIER_VOLTE_AVAILABLE_BOOL
Flag specifying whether VoLTE should be available for carrier, independent of carrier provisioning. If false: hard disabled. If true: then depends on carrier provisioning, availability, etc.
Constant Value: "carrier_volte_available_bool"
KEY_CARRIER_VOLTE_PROVISIONED_BOOL
Added in API level 26
public static final String KEY_CARRIER_VOLTE_PROVISIONED_BOOL
This flag specifies whether VoLTE availability is based on provisioning. By default this is false.
Constant Value: "carrier_volte_provisioned_bool"
That here and that and is important. And yes, they probably were, never argued that at all?Erm .... Vodacom was one of the first, if not THE first operator here to support Volte and VoWiFi. The compatible handsets they had were a issue though. Very limited. And I dont understand why, but getting Volte activated can be a big mission. They should really just run a update on all Vodacom numbers and enable it by default. The handset support I never understood. I have a Vodacom issued Huawei P10 Lite. It have Volte (no icon though. You knew you are on Volte because the network would stay on 4G when you make or receive a call. Could not turn it on or off either. Once it is provisioned on your number, it is always on.) I popped the BF's Telkom sim from his router into my phone to test it as it was giving a bit of issues, and once the Telkom sim was in, all of a sudden I had the option to turn on or off Volte and I also had Vowifi available. When I put my Vodacom sim back in, the option to turn Volte on/off was gone again and no option to use Vowifi either. Why? It does not make sense to me. Google needs to start putting their foot down and standardise like Apple. Volte, Vowifi, RCS.....standard and enabled by default, whether the operators like it or not. Users can disable it in setting should they wish to do so.
Nothing, leave it enabled if you have no issues. Vodacom just had specific issues in the one area where data would just constantly die, so all calls never went through/received, had to disable it and was then able to take normal 3G calls.@Johnatan56 @Ockie What specific steps would you recommend to persons interested in using VoLTE/VoWiFi and what pitfalls should they avoid?
Any chance of that still happening on Vodacom? And how about on MTN?Vodacom just had specific issues in the one area where data would just constantly die, so all calls never went through/received, had to disable it and was then able to take normal GSM calls.
Compatible handsets wise, there have been a lot of compatible handsets that Vodacom never added to the approved list.
In regards to work to approve VoLTE, they probably didn't do it because effort for something that most users don't care about. Ask a random person on the street what VoLTE is, I bet they can't answer.
Elaborated on my answer. No clue, was just unlucky in that area and couldn't take the chance as was for doctor's phone. Can happen anywhere, Vodacom definitely doesn't want it to happen, just took them ages to sort it out.Any chance of that still happening on Vodacom? And how about on MTN?
Elaborated on my answer above, for the network operators it's good if VoLTE, but you need to move enough over for you to be able to phase out the circuit-switching network, which won't happen for a long while yet due to all the phones that don't support VoLTE (most people are still using ancient feature phones). It's why I still think the mobile network operators should subsidize the lowest market level to have 4G compatible phones (as in the R50-100 that the royalties that were incurred cost).Yes, they wont know. That is why operators in US is marketing it is HD Calling.
That reasoning you provided does not make sense to me though from a network perspective. If I were running a network, I would want to almost force as many subscribers as I can to get a compatible device because Volte is a much more efficient way of making a call on the network, and VoWiFi is good for the network in the sense that it can take load off the tower and it is good for subscribers where they suffer from poor signal in a house, but they have for example great wifi via fibre etc.
| PE20JUL80 | P | 104045329 | 103006298 | VODACOM VIBE 4G NETWORK LOCKED + POWER PACK @ R299 CASH |
Where can the subscribers keep an eye on the ever-developing approved handset lists of each provider?If I were running a network, I would want to almost force as many subscribers as I can to get a compatible device
Thanks!Elaborated on my answer.
Thanks!
Yep, India is pushing that segment pretty nicely, which is allowing other networks to benefit.Getting there.
PE20JUL80 P 104045329 103006298 VODACOM VIBE 4G NETWORK LOCKED + POWER PACK @ R299 CASH
Vodacom Vibe 4G review - The 4G feature phone you need in your life - Hypertext
Vodacom's Vibe 4G brings faster connectivity to more folks for just R299 but how good is it really?www.htxt.co.za
