Takealot delivery time for different products
chloroformaa
Hi ..if I add item A in cart, it shows delivery time as after 5 days and if I add item B (not available in stock), it shows delivery time as 20 days...so in this case, should i order both items separately (which I don't want as then total is below 500 rand and no free delivery) to get item A quicker or even if I order both if them together , then item A will be delivered on its time..?..
I mean , if I order both items as one order, then are both items delivered according to their respective delivery times or as per time for item B or whatever takealot feels like..?..generally, what is the case..
Add both to the cart together, it will change your delivery date to match the later one
Normally you can't order out of stock items. You probably mean it is not in stock at your location or it is a item that needs to be shipped X amount of days.
Whichever item is not at your location or need a X amount of days will delay the whole order. So they will only deliver it once all items are at the same warehouse.
I ordered another Monitor and Type-C Hub Multi-Function Adapter is it normal to only get that on Friday? It seems like a long time to wait for 2 things. Ive never waited that long for a delivery from Takealot
