Jet-Fighter7700
Hi all;
I got a bit of a question to do with overheating; My car when I got it; had its radiator replaced with an equivalent unit; but not for my make and model or car;
I drive a 2010 kia picanto and my radiator is from an i10; not sure what model......
anyway this car got no temp gauge and only got a light; at what point will the light come on and warn me to pull over and let it cool down?
or will the light come on just before the engine about to seize up and be ruined forever.......
the reason I ask this is I have a way to see exactly what temp my engine coolant is......
a torque app and ELM 327 scanner hooked up and able to see while driving;
I noticed; right now when I drive on the freeway; temp sits at 89-95 Celsius and varies considerably between those; when Im in traffic it climbs and gets to 100 and keeps going until the fan switches on and then it drops to about 96; but I start getting worried when it gets to 100; is that normal?
or can it get a lot hotter and the sensor is misleading me? and Im being paranoid for no reason.....
is there someplace I can check on the net to see what the range of safe operation is?so I Can set the torque app alarms correctly?
