TedLasso
- Feb 23, 2016
Well, hope that's a cool title!
Finally starting on my reducing independence from Eskom Journey. As usual, while I have read most threads and most installs, I have questions and I know you all going to help me. I think the responses from everyone in their threads over the past few years @AchmatK , @RonSwanson , @Mike Hoxbig , @Tinuva , @itareanlnotani and a whole bunch of others that I can't recall right now have helped.
Starting out: My install is not going to be my dream installation - but I am giving myself the opportunity to start and adapt as time goes on. Also we will most likely be emigrating within 2 years so perhaps not worth investing too much.
The dream installation was going to be a Sunsynk 8KVA Inverter, with Hubble AM2 batteries, and a 10Kwp solar panel array, all tied into HA.
The reality is going to be (Phase 1)
1. 5KW RCT Inverter (I got a free one (brand new but old) RCT-5000MK
2. 1 x Hubble AM2 battery (going to expand to 3-4 as time goes on if we don't emigrate)
This was going to be phase 2 (two months later) but can do it immediately since I don't have to spend approx 35-38K on a sunsynk inverter.
3. 10 x JA 500W Solar Panels mounted on north facing roof.
Base load stats (over last three years): Average 475w day time , 650w night time. I got everything on timers and know/control high draw appliances (geysers, pool pump, heat pump, Dishwasher, Washing Machine with Home Assistant). Max load is about 4-5Kw if ever, but we can control further with smart automation and change of habits which is going to mandatory.
Outcomes Desired :
The Challenges/ Problems:
While I have roofing sorted for solar panels, the location of my Inverter and batteries is a problem. The DB is in the passage and there is no way I am mounting anything there. DB is also full up so no space for anything else. A house built in the 80s.
Possible location is to place in garage but it's too hot in there and cable runs to connect back to main DB is going about 20m away.
We found incoming feed from Eskom side in our patio. Sparky recommended that we mount stuff in the Patio (which is under cover). This solves some issues:- Easy to reroute incoming feed into Inverter and then back to DB. Patio seems to be winning for now because :
Other things I will be doing as part of the initial install
So some initial questions for those that know :-
1) Mounting Inverter and batteries outside - a good idea or bad? Risk of sideways rain is a possibility. For security, I will have a roboguard beam permanently armed monitoring the area. We don't use the patio daily so I and response company will be notified if anybody unknown comes within 10m of the patio.
2) I see that the RCT inverter can be connected to HA. I've installed the software from HACs, but what extra hardware do I need it connected to the network? I can't find any manual for the RCT-5000MKS (it's a 5-6 year old inverter - but brand new). Does anyone have the guide for it? I really do hope it supports blending- Sparky said it does but I need to know for working out how to size the arrays.
3) Buying the Hubble AM2's if I can get it stock. Probably from PowerForum Store or can @DuracellBunny help out here? Do I need a RIOT (if I understand correctly to monitor batteries?)
There will be more questions of course, but happy to be challenged or given other options to consider.
Outcomes Desired :
- Live normally, and use automation to stay within constraints of system. E.g. if on Inverter/Batteries, and base load is 3KVA, and someone turns on oven, don't allow it and notify via notification that system is constrained currently
- Stop relying on Eskom completely if possible.
- it is cooler but exposed to elements in terms of dust and wind so a ventilated cupboard will be mandatory to hide it all . Two reasons for hiding it: Prying eyes as it would face the front boundary wall - which while very high (>2m) is just another challenge for a motivated person and rodents who may like the warmth it offers.
- Easy to add batteries if we need (at least 50cm above the ground) and support
- Ability to swap out RCT inverter with Sunsynk will be factored into designed
- It being outside two bedrooms, will not cause a lot of noise
- If anything goes kaboom, it will happen outside.
- Moving the DB Circuit Breakers for Geysers, Pool Pump and Kitchen Stove, and Kitchen Plugs into it's own DB outside next to the inverter (no space in main DB). It will still be on inverter (essential side) but the DB switches will be replaced by CBI Astute. I will then remove the SONOFF POW R2/R3 in the roofs where I am using them . The primary reason is to keep the high draw stuff together and having them at ground level gives me confidence I don't need to go into a roof should they get borked. I ended up spending one weekend reconfiguring my SONOFFs inside the roof with a laptop, when Eskom had an issue and incoming feed bounced lots in 10 seconds, causing all my SONOFF devices to think I needed them back in factory mode! FWIW, this setting in Tasmota prevents this - setoption 65 1 from happening
- Making provision for the solar panels, MPPT and four batteries in the cupboard design.
- A plug on the supply side, as I am with Eskom prepaid and will need to load units, etc. i will mount this Landgrys unit in the cupboard outside.
