Presence of standard SIP codecs confirms that analog connector (RJ11) is used for SIP. Question is: Where is a switch between CS voice and SIP? I can't see.Compatibility with RJ11 telephone ports; can be set to Voice over Internet Protocol (VoIP) or Circuit Switch (CS) voice mode
Voice service (Alternatively)
VoIP voice:
- SIP voice services
- G.722/G.711a/G.711u/G.729/G.726 encoding and decoding
CS voice:
- CS voice services over UMTS/GSM networks
- CSFB
I got one dropped call after one hour on the line. The same problem, suddenly it stopped ringing, but I can still make SIP calls from analog phone. Ringer circuit blown? Can't verify without opening router.It worked but as soon as the calls get connected it dropped the calls. Then it stopped working completely after that.....
Will try it out again but it is very confusing to set it up because it wants a sip server and sip proxy and both are mandatory fields and can't be the same.... WTF
Any(?) Voip phone has Ethernet port, you plug it to the router like any other LAN device. Enable SIP ALG on the router and configure VoIP phone according to the guidelines on the SIP server Website. Rouer's VoIP settings only applies to the analog phone.I also just purchased this router (Huawei B315s LTE) on the Telkom LTE uncapped plan and I'm looking at connecting it to a VoIP phone via the port on the router. Are there any special settings I will need to make to have priority given to the VoIP connection?
I'm looking at using Switch Telecom for the VoIP service @ R49.00 p/m (call rates seem good). Is there maybe a more affordable service provider with a good quality service?
Is anybody using the B315 successfully with switchtel VOIP? Thinking of upgrading my router and dropping my Linksys ATA.
Do you think my B593 can also work?
It does. It also has build in VOIP feature. I also own a B593 but it's not as stable as the B315 but it does work.![]()
