gorgamin
Banned
If anyone has one of these Telkom Mega 105WR Routers lying around, I've created a guide on how to flash the Routertech.org firmware onto it. The router is far more stable with this firmware, in addition to adding a lot more features.
http://www.routertech.org/viewtopic.php?f=16&t=5954
A guide on how to flash Routertech.org firmware to the Telkom Mega 105WR ADSL Combo Router
This took me a few hours to figure out, and might save you a lot of time. :twisted:
1. flash this exact firmware: routertech-ar7wrd-1350A-pspboot-firmware-4ports-20120130.zip - available here
2. give it 7 minutes or so to stabilise.
3. Login to router (read the documentation included in zip for username/pass/gateway ip)
4. go to System > RT Configuration
5. set led file to bewan700g, and DSP Driver to dsp71A.
6. Save changes, reboot.
I've tested and have had 24hrs uptime, all working.
Also, please add the Telkom Mega 105WR to the list of routers under that firmware file.
Router Upgrade Check 1.4.1 03/07/2014 05:31:15
Router IP: 192.168.2.30
Description: Telkom Mega 105WR
Board type: AR7WRD
Product ID: AR7WRD
Bootloader: psbl
RAM 16.0 MB
Flash (ROM) 4.0 MB
ADAM2: No
No default env: No
Linux version: 2.4.17_mvl21-malta-mips_fp_le
Firmware build: RouterTech_3.7.1B_1350A_20120130_2.97_AR7WRD_psbl
Firmware version: 1350A_20120130
Firmware stamp: 20120130232217
CPU: MIPS 4KEc V4.8
DSP: 7.01.01.00
Annex: A
/proc/wlan: Yes
/usr/sbin/wlan: Yes
TIAP: Yes
TNETW: Yes
Wireless: Yes
WIFI chip: TNETW1350A
WIFI chip conf: Yes
Ports: 4
Ports (according to router): 4
Marvell (or Marvell like): Yes
NSP: 3.7.1B
Manufacturers: Aztech Systems Ltd, Z-com Inc, Cisco Systems
RNDIS: Aztech Systems Ltd
HRNDIS: Aztech Systems Ltd
Select an AR7WRD PSPBOOT TNETW1350A 4 PORT firmware.
Latest: routertech-ar7wrd-1350A-pspboot-firmware-4ports-20120130.zip
Please read the instructions that come with the firmware files before you upgrade.
Note: a later version of the firmware may exist depending on the how up to date the RUC is.
The date-stamp may be superseded, but the rest of the filename should be the same.
According to your current MTD values, you should be able to upgrade using a single firmware image.
This is done at your own risk.
Board type: AR7WRD
Product ID: AR7WRD
Bootloader: psbl
RAM 16.0 MB
Flash (ROM) 4.0 MB
ADAM2: No
No default env: No
CPU: MIPS 4KEc V4.8
DSP: 7.01.01.00
Annex: A
/proc/wlan: Yes
/usr/sbin/wlan: Yes
TIAP: Yes
TNETW: Yes
Wireless: Yes
WIFI chip conf: Yes
Ports: 4
NSP: 3.7.1B
