Telkom Mobile Call forwarding number
graytg
Does anyone know what the call forwarding number is in order to divert all voice calls to voicemail?
:confused:
The same number as you phone for voice mail retrieval. If it is 181 (I don't use voicemail), then:
**21*181# to activate "divert all calls"
##21# to cancel
Or from your phone menu
If doesn't work, you might need to reset mailbox, then dial 181 to reactivate.
##002# to reset
+278114 then your number without the leading 0.
The 14 also works for MTN and Vodacom for example +278214********* for Vodacom and +278314********* for MTN where the * is your number without the leading 0
