s2000 said:If i apply the 3gb , is that mean i can use exceed 3 gb usuage and wont stop the adsl service?
Silent_Bob said:saix based account are meant to be hard capped, my mate has a telkomsa account and so far he has downloaded around 30 gigs this month and no hard cap
HellB0y said:Chaps, it's simple, keep your usage as per normal and all will be fine. There are no more soft caps and all traffic is anywhere traffic, so there should be no effect in the serivce, infact it's an improvement. The serivce is based on a hard cap, however it will only be impossed once the average of 3GB has been reached accross all the subscribers. So it's no glitch it's planned, the higher the average use reaches the sooner the hard cap will come into effect.
So, if you download like mad in the first couple of days of the month you won't be capped, simply because the other people on the network don't know about this yet.HellB0y said:Chaps, it's simple, keep your usage as per normal and all will be fine. There are no more soft caps and all traffic is anywhere traffic, so there should be no effect in the serivce, infact it's an improvement. The serivce is based on a hard cap, however it will only be impossed once the average of 3GB has been reached accross all the subscribers. So it's no glitch it's planned, the higher the average use reaches the sooner the hard cap will come into effect.
I think this is an option for all SAIX ISPs if you take a look at the pre 1 Nov communication sent to ISPs. The problem is that probably only TelkomInternet have a large enough user base to ensure that they don't only have high usage users but have a nice spread of low usage users to high usage users.fivelza said:So how is this fair if all other ISP's are hardcapping at 3gb
