Justin.Tweedie
- Dec 15, 2012
Why is it that Telkom fibre prices are so much higher than other options available. Worse than that they limit the upload to half of the download.
If you unlucky like myself our estate chose to allow OpenServe to implement fibre in our area rather than another supplier. Mostly because they promised a rapid turn around but in the end it's been almost 2 years of hole digging and digging again.
The result is expensive fibre on a infrastructure that can't deliver the 100 / 50 Mb.
I recently did a quick compare and to be fair Afrihost and other ISP's offer prices just as good but WebAfrica was a easy place to get these prices. In some cases Telkom is as much as 3x more expensive than other providers. Since they are not likely to change their approach soon all I can do is encourage others to consider the many other fibre suppliers before allowing Telkom / OpenServe into your area.
