Telkom Wimax - Device Configuration needed - plz help!
Gozzy
Western Cape
Hi All,
IT seems like my device has lost all it's settings in the web config page.
Please can you guys help me out here, I need screen-shots of what exactly these settings are.
If your IP is not in the following range then please change or add another IP so that you can be in the same range as 192.168.254.x
The Device Config page is at : http://192.168.254.251
You can either take screenies and zip or paste everything into a word document and send it to [email protected]
Thanking you in advance.
Jean
K call logged with Telkom........sure hoped this would be faster :P anyways find out it is base station specific, unless someone stays in Fourways and would like to share the CPE's config.
