Thatch replacement
Snyper564
Gauteng
So we have a thatch lapa might wanna replace it what is the going rate for the thatch per sqm and also alternatives? I believe harvey tiles or fiddler thatch tiles, anyone done a conversion any recommendations in Pretoria?
i went harvey over a lapa after thatch ,was around 9 metres wide and 4 metres deep ,against a side wall of the house ,got very hot under there after that,chromadek will be the same
Oi.... I guess even insulation can only help so much.... Pricing just for interest sake
R1200/m2 to remove Thatch and fit Chromodek.
Coincidentally I did just such a quote for a client last week.
I recently chopped down 3 Bottle Brush trees that gave lots of shade at my pool/braai area. I turned a nice red during Sunday's braai. So probably time to look at putting something up. Probably won't be thatch. So watching this thread for ideas.
If you're wanting to do away with the thatch you could consider a louvre awning.
Ja move away from the thatch. Let your mind go. Lots of options.
There is that niggly voice in my head that tells me there should be some solar panels integrated into the mix. But that is very specific to my layout.
I was thinking the same some years ago.
Instead I went the full A frame metal carport style with "Chromeadeck" which is the same size.
Never looked back because of the following:-
1) Less insurance costs
2) Less maintenance
3) Actually looks nicer
4) No worries when morons set off fireworks
5) Less mess on the contents - meaning dust and decay falling from the thatch
6) Less insects
2) Less maintenance
6) Less insects
Ironically insurance does not change PPS is killer with great cover. Called this morning to see if it would
But def on board for the rest!
2) Less maintenance
6) Less insects
possible to share pics? Need other inspiration :)
