Forum Reader
- Aug 25, 2019
My PC has random shutdowns, usually about 15mins after starting it up and in certain games. Pretty sure it's due to the CPU or GPU overheating since if I open up the case and blow out the dust it works fine for a week or two again with no issues, and then the shutdowns start again.
The CPU and GPU are quite old, purchased back in 2015. So I think the thermal paste has hardened and is not making a good contact with the heatsink. It's a FX8350 and a GTX970. What would be a decent thermal paste to use? Will be getting it from Takealot and they have so many different makes/brands.
www.takealot.com
I assume I will also need 90%+ rubbing alcohol to remove the old paste. This is the only one I can find (on Takealot):
www.takealot.com
I think it's most likely the CPU that is the problem but will redo the thermal paste on the GPU just in case.
Takealot.com: Online Shopping | SA's leading online store
South Africa's leading online store. Fast, reliable delivery to your door. Many ways to pay. Shop anything you can imagine: TVs, laptops, cellphones, kitchen appliances, toys, books, beauty & more. Shop the mobile app anytime, anywhere.
