Thermaltake Big Water SE
rpm
Admin
Staff member
Johannesburg
Posted by: Johan Maritz
Description: Brand Thermaltake Model Big Water SE Spec Type Liquid Cooling System Block Compatibility Intel LGA775 / Socket 478 , AMD Socket 462 / 754 / 939 / 940 Block Dimensions 60 x 78 x 23.5mm Block Material Copper & Acrylic Pump Dimensions 66 x 61.5 x 36mm Pump Capacity 90 L/hr Pump Noise 18 dBA Radiator Dimensions 122 x 35 x 166mm Radiator Material Aluminum Radiator Fan Dimensions 120mm Radiator Fan RPM 1300-2400 RPM Radiator Fan Connector 4 Pin Reservoir Dimensions 178 x 139 x 30mm Reservoir Capacity 250 cc plus a extra VGA block worth R250 free Urgent sale, reason for selling is got a Rampage Formula Motherboard don't need cooling anymore
Price: R650.00
