Does anyone know how to connect it to watch the 2 channels without another decoder. Apparently you should be able to watch 2 and record 2 channels?
Nope, there is no decoder that provides this functionality. It is only with 2 decoders that it becomes possible, and now, recently announced, view 3 record 3 is also possible with a combination of Explora and HD decoders.
So please let us know what decoder/s you have and then someone will be able to advise you on what the possibilities are.
The existing combinations with older decoders are:
2 x 1110/1131/1132 = view 2 no record
HD PVR 2P/2U + 1110/1131/1132 = view 2 record 1
HD PVR 4P/4UEC + 1110/1131/1132 = view 2 record 2
HD PVR 2P/2U + SD PVR = view 3 record 2
HD PVR 4P/4UEC + SD PVR = view 3 record 3
2 x HD PVR 4 tuners = view 2 record 4
Note: The SD PVR is no longer supported by MC nor is the HD PVR 4 tuner manufactured by UEC.
Explora + 1110/1131/1132/HD 4U/4S = view 2 record 1
Explora + HD PVR 2P = view 2 record 2
Explora + HD PVR 4P/4UEC = view 2 record 3
Explora + Explora = view 2 record 2
Note The SD PVR cannot be combined with an Explora (Officially), the SD PVR and the 4 tuner UEC is no longer supported by MC.
New:
3 Exploras = view 3 record 3
2 Exploras + HD 4U/4S = view 3 record 2
1 Explora + 2 x HD 4U/4S = view 3 record 1
Note: Support for all older combinations is likely to be terminated at some point.
NO 3 decoder support is supported by MC with an Explora with any older decoder in the mix --- (technically possible, but not supported within the sw or in MCs business plan. No detailed info in the public domain, so this is the conclusion I have come to and not supported by any official information from MC).
