Top Tv signal problems
Mr K
Albany, NY, USA
Hi,
Any body noticed top tv signal problems from last few days.
Previsously, i only had signal problems when there is heavy rain which i think is common.
But from last few days i am having sinal problems even if there is light wind. Even if it is sunny i still get signal problems if there is slight wind.
I looked at my dish and it does not look like it is moving.
Is this problem specific to me or any body elase having the problem?
haven't had anything myside. Maybe a heavy recent wind shifted your alignment?
You are not going to learn anything by looking at the dish. Get somebody out to check your installation.
I thought so as well. But the signal is fine when there is no wind.
If it was correctly aligned before, play to either side would still be okay. If it moved slightly, play to one side might take it out of alignment.
It was fine until recently. So i assume, it was installed fine.
If it moved slightly, will it still work fine when there is no wind? It is working fine when there is no wind.
