Another annoying problem
I currently have my decoder connected to my main tv via RCA, which works perfectly. This weekend I decided to run a RF cable to by daughters room. The first problem is that the picture is very snowy, even after trying to fine tune. The second problem is the audio is just static noise, even after making sure that the PAL setting on the decoder matches what the TV is set to. In this case PAL I on both decoder and TV, but PAL B/G on both TV and decoder did not make a difference.
The cable is brand new, and only 10M long. If I use a shorter cable on the main TV instead of RCA, I have the same problem.
Any suggestions?
EDIT: I also tried changing the output channel on the decoder, same problem.
Any suggestions?
