Totolink with vumatel CPE help
araujo3rd
I currently have a tp link connected to the CPE unit and it gets ip from DHCP and nothing needs to be configured. I would like to connect my totolink nd300 ADSL router which has an ADSL and a wan port to be used as the new wireless router. However when I connect it to the wan it does not get internet access and I am sure it has something to do with the config.
I changed ADSL wan to ethernet wan. And I tried it on bridged mode and DHCP. The bottom of the page shows the link status is up but there is no IP they both show 0.0.0.0. Please can someone help me set this up or is it not possible to do it on this router
Hey there do you have a Raycore Router / CPE
Very simple to solve. Call your ISP's helpdesk and ask them to reset your IP/Mac bind.
If I change the Mac bind do I set the router up as bridged mode?
Hi there yes it is a raycore
Turn off your CPE for about 5mins this normally releases the MAC address from your other router, alternatively call your ISP and ask them to please refresh the MAC your totolink needs to be setup in DHCP on the WAN port for everything to work.
BTW, who is the ISP?
Ok thank you I will give it a shot and if it does not work I'll call them tomorrow. The ISP is crystalweb
This does not work on vumatel. It needs to be manually released by the isp.
