trouble setting up wired connection for xbox360
zeridine
gauteng
I caved in regarding console gaming, and got myself an xbox360 elite, but cant get the networking sorted out.
goal:
i want to stream media from my pc on the xbox .
setup:
xbox360 elite + bravia
PC = D865PERL with onboard LAN (which i havent really used before)
no router - still using old telkom marconi modem for ADSL
winxp home SP2
windows media player 11
kaspersky internet security 6.0
the situation:
i currently have no aspirations to connect to xbox live UK/US. I just want to stream music via PC to xbox (for now). I have very little & severely limited knowledge regarding networks, port forwarding, firewalls, DHCP etc. will fiddle later with applications like tversity, just want the xbox to see the pc for now.
Connected the RJ-45 cable which i got with the xbox, to the xbox and directly to the PC's onboard LAN. ran home networking wizard - found 'Local Area Connection 4'. in media player, i set media sharing on, shared to xbox 360. (as per instruction via www.xbox.com/pcsetup)
on the console dashboard - at the media tab, still cant find the pc! (though mediaplayer can see the xbox)
checked Local Area Connection 4's settings, set TCP/IP's IP&DNS address settings to automatic. Advanced settings says IP address is DHCP enabled. currently stuck even after skimming xbox-360.co.za & myadsl for threads. (at least i still got bioshock to play)
HALP! would you kindly...
PS if the easy answer is 'get a router & replace the telkom modem', which one would you suggest?
thanks in advance
Have you tried turning off DHCP and setting the IP addresses on the PC and Xbox manually?
AAAAAArgh! FFS. it's suddenly working now for no reason! (& after almost having a stroke)
thanks.
sorry for a useless thread.
It sounds like it was the firewall - common issue.
I'd still recommend you go grab TVersity, it's a better experience overall than using MP11 sharing - better menu's better features etc, but does much the same thing + transcoding.
