frankvw
- Aug 8, 2009
I have a Samsung fridge/freezer (about 10 years old), model RB29HWR3DSA, that has problems with auto-defrost. The fridge leaks water because the little draining port at the back freezes up, and there's lot of ice at the bottom. I have ensured the draining port is not blocked with dirt.
This fridge uses a heating element for auto-defrost, including the draining port. The heating element seems fine; it measures about 368 ohms which seems sensible. There is a thermistor clipped to the outflow of the evaporator unit which at room temperature measures around 6k ohm and this rises when I apply cold spray.
However, there is another sensor clipped to the evaporator unit assembly itself which consistently measures 0.2 ohms regardless of temperature (cold spray or heat gun on low setting). I'm not sure if this would be a switch or a thermistor. See photo (I've unclipped it and removed the plastic retention clip).
Does anyone know what type of part this is and what role it plays in the autodefrost cycle or the normal regulation of the freezing process?
All suggestions appreciated!
// FvW
// FvW
