Tshwane prepaid meter help / guide
Mobus
PTA
Tshwane prepaid meter problem / fault finding checklist:
This guide has been cobbled together from my own experiences with my residential Tshwane PCMA prepaid meter (PCR421) and keypad (KY124) - see images below. It is an unofficial guide but can hopefully assist others ironing out issues with their meters before having to log a call with Tshwane. If anyone can help verify or add to this information, just leave a comment and I will amend. Also, let me know if other municipalities also use the same PCMA meters.
Note: this guide is only for PCMA / powercom meters and keypads, and not CONLOG branded devices.
  • If your power is off, the keypad will power from its own batteries, and display an open switch icon. Make sure the keypad batteries are fresh and have enough juice to get the communication signal all the way to the PCR421 meter outside:
    • NB: If you are running a generator or backup inverter, make sure to disconnect from your backup power, and have everything set as you would for normal municipal power usage. Changeover switches should be on mains power etc.
    • NB: all trip switches and circuitbreakers in your DB must be set in the normal up/on positions.
    • NB: plug the battery powered keypad into a wall socket as close to your DB box as possible. Make sure the socket switch is in the on position.
    • Above three tips are CRITICAL to ensure an uninterrupted AC wire connection between the KY124 keypad and PCR421 meter outside, even and especially when there is no power. The keypad uses Power Line Communication (PLC), piggy backing its high frequency comms signal on top of the 240V AC wiring in your house, passing through your DB all the way to the actual meter/relay unit outside your house.
  • Now test the KY124 keypad using the following codes:
    • Press 007
      It should state "PLC" (usually only on the first try). Then "Connect", then give the unit balance 0.00 kWh.
      If it says "Error" or "Null" it means the keypad is unable to communicate with the pcr421 meter unit. Double check the above three tips. Also read PLC lock-up below.
    • Press 009
      Should show "connect" then the current date. The date is being read from the meter and is a good indication that the PLC comms between the keypad and meter are working.
    • Press 005 or 008
      This displays your pcma serial number (I.e. pairing between keypad and meter is still in place). This is read from the keypad memory only and should work even if the keypad is plugged out. An error here might indicate a faulty keypad or that the keypad needs to be re-paired with the meter.
  • Now test your PCR421 meter outside:
    • With everything running normal, the PCR421 is flashing red the pulse LED whilst the relay and alarm LEDs are off. I suspect if your units run out the relay will switch off the mains and turn the relay LED amber.
    • All LEDs/LCDs off probably means no mains power is feeding the meter (upstream problem). Check your neighbours and log a call with Tshwane.
    • Alarm LED on means either some alarm threshold has been reached (though I don't think this facility works with the Tshwane meters) or perhaps the tamper protection has been tripped (TBC).
    • The PCR421 actually has a small oval grey push button on the right next to the barcodes. You can press this button safely and cycle between different data registers. If there is no power from the street, the meter has a small battery and pushing the button will momentarily enable the screen, allowing you to cycle between date/time/total usage(?). If there is street power to the meter, the screen will be on already and pushing the button will also light up the screen. Additional info accessible include pcma serial number (register # 96.1.1 and .2)/unit balance (coin icon, register # 19.0.0)/incoming mains voltage (register # 32.7.0)/immediate current consumption (register # 91.7.0)/current power consumption (register # 1.7.0). The latter two should be near zero if your house isn't drawing any power. If the meter doesn't respond or any of these registers seem unusual, your meter unit might be faulty.
    • PLC lock-up
      In some cases, the power line communication between your keypad and meter can lock-up during loadshedding or switching of the meter relay (e.g. when your units run out). You can try power cycling your keypad by opening and closing the battery compartment. At least in my case the meter had to be reset or power cycled, which is best done by a Tshwane technician or might happen automatically on the next loadshedding cycle. Supposedly Tshwane can also do a remote reset/restart of the meter (see below).
    • Tamper mode or upstream comms lock-out: At least once after loadshedding, my meter also locked up like above (i.e. the keypad and meter would not communicate) but it remained off even after a loadshedding "restart". On the meter LCD, there is a indicator that normally looks like this ●─·─● (closed switch), which changed and looked almost like this ●─┘┌─● (open switch). Note: this is on the PCR421 meter outside, not the keypad LCD which has a similar indicator (but different meaning). On the PCR421 I think this means the meter cannot communicate upstream to Tshwane or has for whatever reason engaged the relay (failsafe, blocked or tamper) and interrupted supply regardless if you have credit or not. An overhead power technician (admittedly not an expert on the prepaid meters) looked at that indicator and said my meter is in tamper mode, and that it happens sometimes due to loadshedding. She phoned in and requested a remote reset or something. She said if that does not work, the meter technician would have to come out. A few minutes later the switch indicator closed and my keypad could communicate and load new vouchers again.
      TL;DR: if your PCR421 has an open switch indicator, it might be worth logging a call here with the following 50 character comment "PCR421 prepay meter open switch icon. Remote reset"
Tshwane installed a Conlog meter at our home on Friday, I am just happy that it is a version which doesn't need to be plugged into any outlets to load new vouchers. I am not sure which meter is actually better.
Tshwane PCMA installed a Conlog meter at our home on Friday, I am just happy that it is a version which doesn't need to be plugged into any outlets to load new vouchers. I am not sure which meter is actually better.
Also got this instaed... seems to work a treat.. no issues yet
Facinating. I thought PCMA and Conlog are two different companies / devices. I am quite surprised that Tshwane isn't standardising on a single system. Do you mind uploading a pic, or perhaps just a model number and link to the conlog model in question.
Which part of Tshwane do you live in? Residential? Complex or sole title? Single or three phase? Do you pay eskom, Tshwane, or a third party?
Hmm. I wonder if Tshwane is perhaps abondoning the pcma system. Or running different systems in different areas. Seems like a pain to implement and manage multiple systems. Perhaps its deliberate after the whole illegal PEU metering contract from several years ago (which used siemens meters, I think).
At least one technician told me that the prepay meters (didn't say which brand) have been given them lots of problems, especially with loadshedding.
We are in Garsfontein X8, Residential single title, single phase and pay Tshwane or third party.
View attachment 1305690View attachment 1305692View attachment 1305694View attachment 1305696
It this still valid advice and codes for the conlog system:
To see the meter number press #100#
For balance check please press #4#
The “Rf con” error message on the keypad may mean that the meter has lost connection to the keypad, due to a long distance from the meter box to the house or something else is blocking the signal. It is recommended that the handheld keypad is taken closer to the meter box pressing cancel/backspace and communication will probably be restored to show the remaining units on the keypad or enable new token to be loaded.
Source/Credit: Leo Middelberg
If I press #4# it gives me the kWh used since reload and after a few seconds it reverts back to show remaining kWh.
The remaining amount is permanently shown.
Does the conlog keypad work only off batteries?
The RF connection to the meter should at least be more reliable than the power line comms of the PCMA. And its nice that the remaining units are always shown. That being said, it might drain the battery faster.
Do you have remote access to the conlog (over local wifi or perhaps via some Tshwane portal)?
Yes it only works off batteries. I haven't seen any portal to access the keypad and there doesn't seem to be a wifi connection as well
So I heard from a guy in "die wilgers" in pretoria that has yet another brand of prepaid meter, installed in march 2022. Landis I think.
What are they doing? At least three different systems across Pretoria that I know of.
Edit:
Supposedly the PCMA meters are giving too many problems, especially with loadshedding. Tshwane just replaced mine with a conlog device free of charge. So far so good.
So I now have the exact same conlog meter. BUT! I am unable to buy new units.
What prepaid provider are you using to purchase vouchers? I used to buy (for the old PCMA meter) with either snapscan or the FNB app, but none of them recognise my new conlog 11 digit meter number.
Do you get an error when trying to buy? Have you tried at a garage perhaps? I use FNB to buy units - Investec doesn't seem to have the provider loaded
I haven't tried buying in store or at a garage but
Snapscan says "Oops unable to check your meter number, please try again later".
FNB says "Your request cannot be processed. System currently unavailable".
ABSA says "The transaction did not complete successfully. Please contact the service provider. Response Code: CODE_05".
Vodapay says "Municipality offline, try again later".
Prepaid24.co.za says the Tshwane system is online at least and sort of loads my meter number into an online cart, but you have to pay via eft or load money into their wallet first - which I haven't done yet as it will *likely* tell me afterwards that the meter number does work yet.
ps. Snapscan still works for my old PCMA meter number, so Tshwane is definitely not all off-line.
Welkom by proudly south african :love::love::love::love::love::love::love::love::love::love::love::love::love::love::love::love::love::love::love::love:
I bought my power through ABSA App.
Recieved a conlog prepaid meter about two months ago, and our electricity bill is twice what is was in the past, asked the municipality to either replace or test the device but it's like talking to brick wall.
