Two+ ISPs possible?
Aharon
Hi,
I think this is really a simple question, but just wanted to confirm:
I have my circuit and a capped account via one ISP, can I get an uncapped account from another ISP and then change my login details based on where I want my traffic to be routed?
Aharon
Yes... you can even put your router into bridge mode... or half bridge mode and create the PPPoE connections for the various ISPs on your computer and just "dial-up" to them as needed.
But ja... you can change the settings in your router to your other ISP as often as you need.
Hi,
Aharon
As a myBB member since 2006, you should already know the answer ======> YES.
Can you actually dial an additional account if you've moved your line to an ISP like Cybersmart?
I know I can dial multiple ISP accounts on my ADSL line that I'm renting from Mweb.
Yes.
