Hi Guys
I am hoping you guys can help.
I have a Hikvision POE switch (unmanaged) and a UAP-AC-LR access point. The poe functionality was working fine for a year but now the access point does not power on. The only way I can get it to power on is if I use the POE injector that can with the access point. I did not change any settings on the switch or accesss point. Both the switch and access point are 802.af compliant.
