Unifi Captive Portal help please
getafix33
Hi
Infastructure
pFsense Firewall - WAN with static IP on port 1, LAN, VLAN40, VLAN50 on port 2
3 x Unifi AC LR's
3 x SSID's (1 x Default lan, 1 x Tenant, 1 x IoT)
Tenant and IoT are on separate Vlans with Tags of 40 and 50 respectively with Guest Network NOT enabled
However, whenever I try to connect to any SSID, a Apple.Captive.Portal pops up. If I cancel, I can access the internet.
Any idea what would cause that?
I know PFsense have some sort of a Captive portal from what i remember, have you gone through the firewall settings? I Don't think its Unifi related as you haven't marked the SSIDs as guest networks.
Does it happen on multiple devices or specifically limited to this Apple device.
Pfsense does have a captive portal. Its a new installation and I dont recall enabling it, but will check. It happens on both my iphone as well as Air.
Will double check the other devices
Thanks for the reply
