UnTangle Problems as usual :(
Jizzims
Banned
Dudes
Ok so i downloaded the Untangle Windows based version
I have a HP machine 1 network card wired to the router wanted to test it last night but the Dam thing keeps saying service could not be started ???
was up since 20H00 to 02H00 trying to figure it out and no luck Anyone else have a better idea or program ??
Details, details, details :D
What's the exact error message? Maybe look the Event Viewer and paste here...
will post tonight
Basically a screen is suppose to come up after installation mine dosent... it drops to taskbar then error : Ubuntu service could not be started ? ok so i go to services its not started i try start but it tells me no thanks with no reason....
i start virtual box it loads with a few fails here and there then BOOM resets my machine
will give you guys specific details tonight
thanks
I'm sure you need two nics. One red faceing the internet and one green facing your lan.
