uploaded 1.9GB - help !!
flashfire208
JHB
Hi all , i checked my usage statistics today and found that on the 13th i uploaded 1.9 GB !! 100 fold more than usual ! i only use the line for internet surfing and some gaming . what could it be ??
Could be a gaming updates from Gamespy? or other servers...
could also be windows automated update software for all the program's on your pc
yep ... 1 DAY. Doubt it was an update , i only play COD4 online ... sigh ill call webafrica tm.
this is 2 nd time its happend :(
Hope they used vaseline! If it was uploaded then you've been r@ped!!
Firewall?
Eish ... ill scan for malware and the like and tell you if anything comes up
You running any other peer to peer software that maybe has something shared with the world?
It might be a p2p client running in the backround like utorrent - left seeding?
or
Maybe someone has gotten hold of your ISP details and uploaded loads of data - enable DSL Secure through the DSL console if you using WA, that will only allow connection to your isp from your ADSL line you can add and remove lines if you wish.
nope no limewire or torrents . thanks for the suggestion ry4n , now i just have to remember my own password to get into the console ...Hmmmm...
if u cant remember PM me and I will tell you ;)
joking but if u wanna know how to get it (if its in ur router) PM me.
