USB device not supported on S21+
Heksmeester
Pretoria
I've recently upgraded from an S9 to the S21 Plus. Since there is no longer any headphone jack, I bought an Aux to USB-C adapter in order to play music through my car audio system however I am getting the following error message when plugging in the adapter.
"The connected USB device is not supported."
This error pops up immediately after plugging it into the phone's USB-C port without being connected to the car yet. It does not appear when using the adapter with my S9.
Any ideas on what the problem could be?
I have exactly the same issue after also upgrading from the S9+ to S21+.
From what I understand the USB-C adapter must have its own DAC to work with the S21+.
I also read that you may have to turn on on the option "Disable USB audio routing" in Developer options for the adapter to work.
I currently have the adapter below on backorder from Geewiz which they say should work as it has a DAC:
https://www.geewiz.co.za/cables-ada...type-c-charger-with-dac.html#/14-colour-black
Below is a link to an article that lists adapters that should also work:
https://www.androidcentral.com/best-usb-c-audio-adapters-galaxy-s20
I hope this helps
  • Like
Reactions: Yuu
I use this
[US$11.81 51% OFF]Baseus Car bluetooth 5.0 FM Transmitter 2-Port USB Charger QC3.0 Quick Charge Digital Display bluetooth Audio Adapter Car Kit With Microphone Handsfree Call 3.5mm Aux Input Music Play Mobile Phone Accessories from Phones & Telecommunications on banggood
  • Like
Reactions: Yuu
I hope this helps
Thanks for the info!
