I want to use my HTPC as a CCTV system as well. SO I got the software to see any connected webcam's feed via the web on my cellphone or work pc: it works!.
Now, I'd like to be able to move the webcams up to 20meters away. One for the driveway, one for the front door etc.
Apparently USB past 5m is not going to happen unless it is an active extension. How would i know it'll work anyway?
It seems you can do extensions using CAT6 STP. Does anybody know how to DIY a cable like that?
The local sellers of USB over CAT extenders don't mention whether it is USB2 or 1, which probably means it is USB1 that won't work.
