Roman4604
Got tired of the shlep of burning Divx/Xvid files onto DVD+RW disks for use in my LG DVX173 player. Also over time the disks get scratched and the LG's drive seems more prone to read errors resulting in no audio or speech lag every now and then.
So decided to invest in USB based solution comprising of Philips 5986K player (R599 HiFi Corp) & Kingston DataTraveler 4GB USB flash drive (R272 pcint.co.za).
In general the setup works great, however I have 2 gripes;
1. Philips does not has a jump to time in Divx function like the LG had, but at least the quickest FF runs at ~1min per sec so it doesnt take too long to resume watching at the end of a file.
2. A bigger niggle is the slowness of write speeds on the the Kingston. I'm getting 4-6MBps, which is little better than the 4x speed (on +RW disks) of my DVD writer . Tried on different machines (setting USB 1.1 or 2.0) and it makes no difference so it must be the flash itself.
My Q is anyone know where to get resonably priced 2 or 4 GB flash drives with (much) higher write speeds?
