vodacom3g
Vodacom Representative
I get the impression there's been more posts lately from forumites who say they battle with USB modems such as the E220 disconnecting frequently. Often it is indicated that a software/PC restart is needed to reconnect or you hear the USB connect/disconnect 'chime'.
Obviously there could be various reasons for this, like cell breathing but I want to focus on powering the modem in this thread.
I'd like to get more feedback / symptoms on this from you guys and especially would like to know how you power the modem. For example:
1) Plug it into a single USB port using a normal USB cable.
2) Plug it into 2 USB ports using the dual-plug cable.
3) External USB powered hub.
Maybe the mods can nail up a poll for this. Something like:
Options 1 - 3 ) I get disconnects and I'm using one of the above 3 methods to power the modem.
4 - 6) I don't get disconnects and I'm using one of the above 3 methods to power the modem.
7) I get disconnects but don't believe they're power related.
@ic, you're normally quite good at designing these polls.
